Old 10-21-2013, 11:04 AM   #4
dghii
Take the headlight assembly out using the removal tool in your car's tool pouch. You will see the multi-pin connector on the back of the assembly. It's make is part of the tray that the assembly slides in on.
I had a 98 that had a the connector broken from the tray. There was still enough wiring harness to connect the assembly as I was sliding it back in place.
