Thread: cooling fans
Old 10-20-2013, 04:38 PM   #2
Heiko
Heiko's Avatar
The are controlled separately but should come on together at low speed... and if the AC is on they will both run on high that is correct.
If you're wondering if they are working right, you can do two tests.... 1.) See if you can get access to a Durametric and run a quick fan test on each... or 2.) you can look at the Relay panel over the fuse panel up in the driver side foot well. The fan relays are in the lower row right side relays (4) - Check the relay chart... from right to left is: right/high - right/low - left/high - left/low. A manual test can be run on each bridging sockets 87 and 30 on the panel side with a short jumper wire.... if the fan doesn't work on one of the low speed relays then likely one of the resistor packs on the fan units up front (each fan has one).
Heiko
Previously owned:
