Old 10-18-2013, 08:23 PM   #1
utkayaker
Thanks to both of you!
It idles smoothly but runs a bit rough if I pull the oil fill cap off.
One thing I didn't do either is check to see how much oil is left after it smoked and blew a good bit of oil. I am now wondering if I can't find the leak because there is not enough oil in the engine to "feed" a leaking spot.
I am really starting to suspect that it is the front right spark plug tube.
Can I run the engine without reconnecting the AOS? Should I go ahead and replace the AOS even though it is probably ok? (I just bought the car so I don't know how long this unit has been installed.)
THANKS!!!
utkayaker is offline   Reply With Quote
