Old 10-18-2013, 06:22 AM   #1
Mikluuutus
Boxster S 2000 door problem - need help
Having problem with passenger's side door, door doesn't open.
Using remote to lock the doors, everything goes locked. Trying to open the doors, everything opens but passenger side door doesn't, car give 2 beeps.
Door won't open from inside or outside handle. It just refuses to open. When pressin opening button from the remote, you can hear something is moving there but door refuses to open. Been driving 3 weeks without getting passenger door open, then suddenly one day it opens normally. After driving locked the doors -> again same problem, passenger door won't open. Used car for two weeks and one beautiful morning it opened again. What's wrong with it, what do you suggest to do?
Here is the picture of Alarm input signals, when both doors closed: http://www.amigosracing.eu/wp-content/uploads/2013/10/021013_MLM991.jpg
I'm wondering why driver's side says door secured but passenger side don't?
And here is the fault codes:
Alarm I32
Module Identification
Part Number 996.618.260.06
Supplier Part Number 080504003007
Current Fault Codes
60
Central locking limit position Lock not reached
Status: present
Occurance Counter: 1
47
Control locking synchronization
Status: not present
Occurance Counter: 2
This fault is displayed for informational purposes, it is not an indication of a problem and no repair is needed.
Door(s) secured and terminal 15 on
Status: not present
33
Interior sensor faulty
Status: not present
Occurance Counter: 6
59
Central locking limit position Secure not reached
Status: not present
48
Airbag signal acknowledged
Status: not present
10
Voltage failure at terminal 30 with alarm system active
Status: not present
Occurance Counter: 3
43
Alarm actuation by passenger's door
Status: not present
44
Alarm actuation by driver's door
Status: not present
61
Central locking limit position Unlock not reached
Status: not present
Thanks!
Mikluuutus is offline   Reply With Quote
