Old 10-16-2013, 06:44 AM   #1
Last930
Dropped engine sump pan
Yesterday my mechanic removed the sump pan on the '04 Boxster S; to my delight it was spotless - not a spec of plastic, metal etc. It looks like the oil leak - which I had assumed was coming from the RMS - is actually coming from some place near the top of the engine. It is possible that something was missed or cracked during the AOS replacement when I first got the car.
The quandry now is do I go through with the hassle and expense of a new clutch, RMS and IMS bearing if the oil leak is not from the RMS? The clutch is a little hard to push in, but doesn't slip or chatter; car has 95K on it. I'm inclined to fix the oil leak then keep driving it as is and watch the oil filter for debris. I can live with the clutch, and hopefully if the IMS bearing has held up this long it probably turned out to be one of the good ones.
Last930 is offline   Reply With Quote
