Old 10-15-2013, 02:18 PM   #2
The Radium King
The Radium King's Avatar
they'll probably tell you it is normal. some cars do it, some cars don't. some cars do it when hot, some when cold. the aos lets a bit of oil through even when working properly, so a puf of smoke on startup should be ok (but not a smoke cloud). if the aos failed recently and was replaced, residual oil can cause a puff on start. maybe it isn't oil at all but rather condensation in the exhaust burning off? also note that these are horizontally-opposed engines, so the cylinders lay flat (as opposed to a 'v' type engine) and oil may seep into the combustion chamber if it sits long enough and smoke on start. if you think this is the case then perhaps ask for a compression or leakdown test as part of your pre-purchase inspection to make sure there is no scoring or cylinders going egg-shaped..
