Old 10-15-2013, 11:16 AM   #1
Heiko
Heiko's Avatar
Yes can be done easily... If careful you can do it without removing any hoses.. Just loosen the tank enough so you can get enough space to clear the sensor out the bottom. Pull the plug on the old sensor, turn it 45degrees and pull it out. Carefull not to break the new one when you guide it back into the opening.
H
Previously owned:
