Old 10-15-2013, 07:26 AM   #10
Perfectlap
Perfectlap's Avatar
I suspect that if these cars were driven more traditionally (10 - 15k miles/year) their reliability perception would go up, IMS failure % may go down.
So I replace, water pump, front suspension, etc at 65k miles thats terrible - How Unreliable
BUT replacing at 12 years old now that's not bad at all - That's pretty reliable
My car does protest when I don't drive it regularly
not sure if you are being tongue-in-cheek but 65K miles from a suspension on a low-sitting sports car is not bad. Especially if its been subjected to low profile tires and heavy aftermarket wheels over urban roads.
The water pump issue seems to me, and this purely anecdotal, to be an issue of a Porsche component that has little margin of error for any air in the system. The coolant cap is a weak spot and I often wonder if all those who had multiple water pump failures kept up with the updated caps or simply changed them every couple of years to ensure a tight seal. I doubt it. Then you have the coolant tanks that are a second weak spot that are prone to cracking. My point being that the waterpump has to be addressed as part of a group/eco system of items and not just one thing alone. I don't think this is the standard procedure for most owners when it probably should be.
BORN: March 2000 - FINLAND
