Old 10-15-2013, 06:01 AM   #17
southernstar
johnsimion, if the IMS worries you that much and you are unwilling to pay for an upgrade, then sell your car. Of course, if you want to replace it with a legitimate sports car such a BMW Z4, you will find that there are significant issues lurking in those cars as well: the rod bearings, already referred to, and the electric steering pumps that fail regularly and cost about $3000.00 to repair, etc.
Frankly, I consider the reliabillity of the 986 to be terrific considering its age and typical use: take virtually any car that is now between 10 and 17 years old and consistently drive it within an inch of its life and see what happens! Yes, the single row IMS bearing was a huge mistake - but, and it is a significant but, there are fixes and, in the case of the initial single-row bearings or dual-row bearings, ones that are not terribly expensive.
What other car for anywhere near the current price of a 986 can deliver comparable steering, handling, braking, acceleration, sound, ergonomics, appearance and yes - class? Considering the age, for those who don't live in Arizona or California, what other sports car is as resistant to rust? This is not an insignificant feature as rust is not only unsightly, it weakens the structure and costs an absolute fortune to repair properly- if it is worth repairing at all.
Consider the much maligned interior quality in the 986: in spite of their age and the fact that they are often exposed to direct sunlight with the top down, the interiors have actually held up very well - for example, how many 986's have you seen with a cracked dashboard? One has to compare apples with apples and it is unfair to compare any convertible to a hardtop in terms of interior durability.
Consider the brakes - in spite of much harder use than the average sedan, the monoblock 4 piston calipers are extremely durable and do not require replacement with most brake jobs.
Consider the exhaust - how many 10 to 17 year old 986's still have their original exhaust system?
Consider the cooling system - a mid-engine, water-cooled engine will always be much more difficult to engineer and to maintain and the one in the 986 is more efficient and reliable than in virtually any other mid-engine car. When properly maintained, air locks are extremely unusual - and compare that to various Ferraris, Lambos, Maseratis and Fiat X-19's, etc.
Is the ignition switch an issue? Absolutely, but the part costs about $35.00 and it requires about 1.5 hours of difficult, but not expert labour to replace.
Are some of the plastic parts an issue over time? Yes, but is anyone really surprised that a plastic coolant expansion tank or A/OS may be deteriorated after a large number of years, considering the continual heating and cooling and pressure that they have been exposed to? If you are, you may wish to check out BMW or even more mundane brands.
Consider the intended use of the vehicle. In order to obtain the incredible balance of handling and performance while providing decent comfort and ergonomics, wieght had to be kept to a minimum. Porsche used magnesium top bows, aluminum suspension components and various other means to keep the weight to a reasonable level. However, designing and building a car where weight reduction is a priority can lead to parts that are, at times, less durable than their heavier equivalents on more mundane transportation. Just ask the owner of any Lotus, if you have any doubts about that. Again, as perfectlap has pointed out, we have to compare apples with apples and it is unfair to compare the durability of a Porsche with that of a Toyota Camry.
In terms of a car's expected life-span, the 986 Boxster is now a late middle-aged (or older) car that is still capable of providing virtually state of the art performance. In spite of its age, it is still not only capable of, but happy to be driven very hard and it does so with only occasional protest. IMO, the 986 is akin to an incredible athelete who can still 'bring it' in spite of being in their late 30's or beyond. Sure, at that advanced age such athletes typically spend more time on the disabled list than their younger (or much younger) competitors. But the amazing thing is that they are still able to compete at all!
Brad
southernstar is offline   Reply With Quote
