Originally Posted by Topless
Who ended up selling this design - particularly this aspect:
Post 169: "...What I am developing is a setup that takes the swivel point from inside the shaft, and moves it to outside the case. With my setup, the bearing insert has 2 steps that support the shaft on different levels to make it rigid in the shaft, the bearing is supported in the case halves, where as the original setup, the chains pull on the bearing and shaft (like a lever) causing the inner race of the bearing to deflect and case to flex..."
