The problem with the OBD reader is that:
1) you need a wireless type connector for the obd port. Thats all fine and good, except the bluetooth connector I got stays powered even with the car off, so I can't leave it in the car (hassle).
2) It definitely needs to be wireless because with an iPad, you won't have a way to connect it up (iPad connector will be used for power).
The app for apple devices is much more limited than the Torque app for android. I also didn't find a way to link my non-jailbroken iPad up to the bluetooth connector. I needed it to be jailbroken so that you can install the bluetooth hack that allows the iPad to see all bluetooth broadcasts and not just approved ones. The non jailbroken iPad did not see the bluetooth network broadcast form the obd connector.
