Old 10-13-2013, 04:33 PM   #19
rp17
rp17's Avatar
The boss sticks out far enough to almost touch the back side of the pulley. The belt surface just wraps around it on orig pulley.
The UD pulley will rub into the boss. It's belt surface is dead even with the boss. So I used a sawzall and cut mine off. It would take a while to file down. Cut off flush or slightly proud.
I do not suggest you use a sawzall unless you are skilled with one. I've been using them for many years.
Nice job with the sawzall. Need to do some research on the best way to get the clearance. Thanks for the reply.
