Can you get under the car to look? How about looking at the water pump from the passenger compartment? You will have to remove the carpet behind the seats and remove the cover. There will be coolant or residue behind and below the water pump pulley. Also, you can remove the belt and spin the pump with your hand to get a good idea of the condition of the pump. If the pulley wobbles or the pump make any grinding noises when spinning it's bad.
Jäger
300K Mile Club
