Old 10-13-2013, 08:57 AM   #10
Shehadehd
Shehadehd's Avatar
How much material have you had to remove? What head unit are you planning on using? Looks great so far!
I've removed the raised edges on the bezel. When I am able to get out the bezel in my car I'll do a picture comparison of the two. Basically I flattened the bezel. As far as the head unit goes, no idea. It just needs to have an aux in on the back lol. One other cool thing is that the iPad can connect to the OBD II system and provide real time engine diagnostics while driving
I hear that epapp is working on a "true solution" for the IMSB problem that can actually give you realtime info about the IMSB condition and if it pans out well, there may be an app that you can put on the mini and monitor the IMSB while driving. *this is all speculation btw*
The result makes the iPad really flush with the clover portions if the bezel.
Shehadehd is offline   Reply With Quote
