Originally Posted by epapp
Skeptic or not, stick around.
Yes it is arrogant to say real engineering...blah blah blah. We are allow working towards the same goal here, I just have to make myself feel like my solution is better so I will actually build the damn thing.
I will promise one thing: my IMSB health monitoring solution will be conclusive. If I release it, it will be because the data is reasonably accurate and can be replicated.
Once I can judge my IMSB health, I will probably need to crowd source for some more data. Since I don't have 10 boxsters laying around, I'll need a way to gather data of different IMSB healths to make any kind of judgement.
Sent from my iPad using Tapatalk - now Free
Be prepared to force an engine failure under controlled conditions with the system employed. I sacrificed two engines during the development of the IMSG, one of which was specifically built to be killed by installing an IMSB into it that was already at stage 3 IMSB failure.
If you need to gather this data and gather the data I do have these engines in my lab and they are available. Currently one of them is being used for similar research, so a compound test may be possible.
Projections and assumptions don't cut it.
But it wouldn't be cheap.
