I've had this problem and for some reason I believe that this is temperature driven problem . When the temp is over 180 it is less likely that the problem will happen and the other thing that has been mentioned is shifting at higher revs( forcefully) and the second gear goes in with no problem. I don't remember when this problem surfaced but the dealer ran away from it by blaming on the engine temperature. I blame porsche since I don't believe it should happen at all.
Pluralitas non est ponenda sine neccesitate
