Thread: code reader
Old 10-11-2013, 11:12 AM   #8
JFP in PA
Originally Posted by tommy782 View Post
ok thanks for the info JFP. so if I understand if I buy a cheap OBD2 reader, I will not able to clear all the code and occasionnally the code reader can give false code right?
so all the cheap code reader I see on ebay can't work on porsche exact?
No, there are several "proprietary code areas" in your car that a "global" (read cheap) OBD II scanner cannot see or clear codes; examples are airbags, ABS, PSM, etc. A lot of cheap scanners also throw either improbable or non existent codes as well, which tends to send you on wild goose chases.
There are some good aftermarket scanners, like the Actron mentioned, but even that cannot see or clear many codes.
