Old 10-10-2013, 10:17 AM   #10
Topless
Track rat
Topless's Avatar
Originally Posted by Hayden View Post
I agree with you. Went in to my indy, they said I needed new brakes (46k on odo) and I was enthusiastic about changing them out, but then the shop (diehard porsche fans, mind you) says I need new rotors, etc., and then throw that price out there.
What happened? I walked - can't afford that for just a brake job at this time, or anything else on their list that I got done for 25%-35% less at another porsche mechanic who is much more laid back about this stuff. Regardless, I have a brake pad light on and compromised safety with a car that is off the road during prime top-down weather.
Which is the better scenario for that customer on the road a few months later? I presume the "can't afford to drive a porsche" argument will be used against this statement. Maybe they are right in their recommendation--I'm not going to say they are flat-out wrong--they aren't. However, their "go oem or go home" attitude is well noted in the local community, and a turn-off for lots of customers.
Well, driving around on worn out pads and out-of-spec rotors is probably not the best plan. Maybe time to learn how to do your own brakes.
New or turned rotors is just standard procedure and good business for a Porsche shop. It makes certain that the cars brakes are at their best and feel smooth, fresh, and new which eliminates callbacks from: "You guys said you did my brakes but I still hear a grinding noise. I'm not leaving until this car is right and I'm not paying for a job half done."
We Porsche drivers can sometimes be a PITA
As a DIYer, I never resurface a rotor measured within spec that I deem serviceable. If it is heavily grooved, I go new. Rotors are cheap and expendable with front OEM Zimmermans at about $100. Hospital stays are expensive so choose wisely.
