Old 10-10-2013, 06:03 AM   #10
The Radium King
The Radium King's Avatar
if you buy the harness you can find the wires intended for the speakers and trace them back to the connector - that will tell you which pins on the body side are for the speakers (note that the car is not wired for door speakers on the body side either). then you'll have to find the little bosch pins to insert on the body side connector to run the wires to your dash speakers - for what it's worth they are the same as the pins on the rear defroster wiring harness. ps, confirm that you get the proper harness as there are many variants out there (search thr online parts cstalog on auto atlanta to see). final warning is that wreckers dont take a lot of care to remove these things so expect a lot of broken plastic tabs, connectors, etc.
