Old 10-09-2013, 02:01 PM   #12
woodsman
woodsman's Avatar
Originally Posted by Bigsmoothlee View Post
As a shop owner, I personally took offense to your claim of "dishonesty" . I am straight forward with my clients, and I never use scare tactics to get people to do their maintenance in my facility.
In my experience, whenever I put a used rotor on the lathe, its usually worn unevenly or warped. This causes vibration and causes the pads to become noisy. The groves in the rotor overheat the pad ( since maybe 40% or 50% of the pad is making contact with the rotor until it breaks in ).
Can you get by if you slap new pads on an old rotor? Probably. Will you get cancer watching your food rotate in your microwave from the radiation coming out of it? Maybe, maybe not. Should you accuse a shop of being money hungry because they want their client to do the job correctly? Absolutely not.
I think clients would appreciate the OPPORTUNITY to gamble on their old rotors (turned or not) before they fork out for new ones. I know radial run-out can be a persistent problem but so can over-cautiousness or a lack of sufficient funds.
