Originally Posted by Slate 01
That little spring on the Door storage compartment is a ******************** to put back on, I tried to reinstall for about hour and a half, finally gave up for today and take another whack at it tomorrow. Any suggestions?:ah:
Put the spring on the door with a dummy hinge pin that will get pushed out when you push in the actual hinge pin. The dummy pin will hold the spring in place while you are trying to line up the holes in the arm rest and the door.
