Old 10-08-2013, 09:23 AM   #1
rijc99
FS: Schnell Boxster, 996 & 996 Turbo Short Shift Kit
Schnell Short Shift with stock 986 console thrown in so you don't have to modify yours. (Stock bushings for the original shifter has been cut so I no longer have any use for it but you can use it to install the short shift.)
The Schnell Short Shift has never been driven on. I had a shop install the shifter. I then sat in the car and tried shifting. While shifting around, I discovered my car has bad synchronizers on the third and fourth gear. The short shifter was amplifying the problem and since I have other more pressing repairs on the car, I have to put off the transmission fix until later.
The Schnell Short Shifter is therefore a no go for now. I have the invoice showing purchase date of 8/26/14 and invoice date of when I picked up my car from the shop where I had it serviced with a date of pickup from late September.
Since I'm including my original console for you to use, you don't have to modify yours. So, you can swap shift consoles back and forth whenever you want.
I'm in Orange County, CA and can meet if you are local. I can also ship.
$175.00
rijc99 is offline   Reply With Quote
