My SPB also has a 2 pole switch. It is mounted near the battery and opens the ground connection from the battery to the chassis - so everything is killed. It has pull wires going to the dash and the cowling in front of the windshield.
Correction: I took a closer look at the switch and see an addition pair of contacts with small wires attached that go inside the car, so mine is not a 2 pole. Sorry for the mistake.
Reason: correction
