Old 10-08-2013, 07:34 AM   #5
ivectoru1
ivectoru1's Avatar
Originally Posted by JaxJim View Post
Great detective work! Thanks!
N00b question: Can the replacements be installed from the exterior of the vehicle (i.e., just the caps), or do you have to open up the front trunk to get at the washer?
Again, thanks!
You don't have to pull assembly or anything. Make sure the empty nozzle ports are clean/dry then lightly prep with VERY small amount of pipe cement or krazy glue. Pre-aim the nozzles as you set them in the ports, because the'll set fast, and won't pop out again!
ivectoru1 is offline   Reply With Quote
