Old 10-07-2013, 12:10 AM   #1
pjq
Its not that bad if you have time. Its kinda cool how they put it all together and fit so much into such a small cavity. Its like a plug and play engine. To work comfortably under the car I had the back of the car 24 inches off the ground measuered from the rear jack point. It just so happens a 30 ton bottle screw house jack is this tall. Thats what the car is sitting on in the rear. The second picture is how high you have to lift the car to slide the engine out after you have dropped it down. That is without removing the structural cross member.
