Old 10-06-2013, 01:53 PM   #1
JFP in PA
Originally Posted by Lordblood View Post
Hey everyone, I've lately been experiencing some grinding when engaging 2nd gear. It doesn't happen every time, usually on cold starts, and usually all the gears become a little less smooth to shift into. I'll notice that the gear doesn't slot all the way into 2nd, and when I let off the clutch that's when the grind will begin.
I'm not sure if these are bad syncros or maybe transmission mounts? I'm hoping the issue is fixable because not only is it annoying to not have 2nd gear sometimes, but I'm sure I'm loosing teeth on 2nd gear the more it happens. What should I check for?
EDIT: Forgot to mention, I drive a 2001 S with a 6 speed manual. Has about 70k miles right now and I drive mostly in town.
What gear oil is in it?
