Old 02-05-2006, 01:02 PM   #2
RandallNeighbour
Is the top up or down? If it's up, make sure the recessed switch in the hole where you put the top hook is working. That has a lot to do with your windows working or not.
Try this...
Put your key in the door and turn the key all the way to the left and hold it. Then to the right and hold it. This should make your windows go up and down. If this doesn't work with both windows, you probably have a regulator out. That's my guess.
