Originally Posted by dghii
If you are referring to the passenger side, check the AOS. With car running, try to remove oil cap. If there is excessive vacuum, your AOS is suspect.
You can also access the top of the engine and look into throttle body for evidence of oil.
I have the same symptom as the O.P. I was hoping it could be the AOS because I could do that for $140. Then I was deflated by reiver saying that an oil leak can't be the AOS. Are you sure? More oil comes out of mine on a long right-hand turn at the track. A guy following me said it was coming out the right/pass side, not the exhaust.
