Old 10-01-2013, 04:37 PM   #1
AKnowles
AKnowles's Avatar
KTS-500 to OBDII pinout?
My KTS-500 to OBDII cable was hand made and apparentlyu had a bad solder joint. One wire is no longer soldered to the 20 pin KTS connector so I can't use my PST2 to reset my codes (aside from using the battery discconect method). I've done a LOT of searching on the internet, but could not see to find a DIY on how to make your own cable or a pinout for the KTS side of the cable.
Does anyone have a document with the pinout on it I can use to fix my existing cable?
