Old 02-04-2006, 09:12 PM   #2
eslai
You already ordered it, right? I'm sure you'll be introduced to a service advisor there--I suggest you get friendly with him so you have someone in your pocket in case anything goes wrong.
Inspect everything on the car before you drive off the lot. You probably won't find any problems, but if there ARE any you'll want to know before plunking down the cash! Take it for a test drive before finalizing the paperwork. Top up, top down.
Oh, and pop the frunk and look at the battery cover. Mine seems a little misshappen--when it's properly attached it still looks misaligned. I looked at another car on the lot though and it seemed to have the same problem, but I've seen others since then on which I didn't think the issue was as prominent.
2005 Seal Grey Boxster S
987 Amberectomy
eslai is offline   Reply With Quote
