Old 09-27-2013, 03:58 PM   #15
JFP in PA
LNE uses triple row bearings on their rebuilds? Is this the same as the plain bearing in the IMS Solution?
No, it is a special shaft and triple row ceramic bearing assembly that can only be done while the engine is apart. The plain bearing "Solution" only comes in the single row bearing size, uses a pressurized oil feed off the filter out line and has no moving parts whatsoever, and can be retrofitted to an assembled engine.
