Old 09-26-2013, 09:12 AM   #3
southernstar
I too have MIchelin Pilot Sport Plus and although I do not drive my Box in the winter, I can definitely echo Mark T's comments concerning wear and performance in moderate to warm temperatures. Having said that, if you have winter tires and rims I would use those once it gets cold as the tire compounds are designed for colder termperatures and the tread and narrower contact patch are imiportant in the snow. If you are buying summer tires with the expectation of only using them for the remainder of the fall and next spring, I would purchase a more performance-oriented and less expensive summer tire than the michelins - let face it, wear will not be an issue!
Brad
southernstar is offline   Reply With Quote
