Originally Posted by max_asdf
When the tank leaks, where does it usually leak to. Inside the trunk?
Yes - lift up the carpet under the tankand look to see if its wet or ifany fluid is lying there.
When my tank leaked (at the rear of the tank so it wasn't obvious), it was only a slight weep and only when hot. Enough to lose half a cupfull every 500 miles or so.
