The clips marked in red are fairly easy to remove. Pop the cables and wire out of them then simply unscrew them. They screw into a bolt that's welded onto the rear firewall. To re-install them you must guide the lower clip portion over the strut while holding the center part square relative to the bolt. Don't overtighten them becuase the plastic will strip.
The caps marked in green are again only plasic covers that screw into a bolt welded to the shock tower. They can be tight but I found that using your hand to apply a twisting pressure to the outside of the cap exerts more force than a screwdriver in the plastic slot. I wouldn't worry if you strip or break either of these plastic parts, they aren't very expensive to replace.
Cogito Ergo Zoom!
I Think, therefore I go fast
Current Porsches:
2004 Cayenne Turbo
2003 Boxster S
Past Porsches:
1989 911 turbo
1981 911SC
1984 944
1973 914
