I would do
Check for any vacuum leaks
With engine at idle, see if you can remove the oil filler cap - test for bad AOS hard to remove is a bad sigh. Search AOS.....
When is the last time the Mass air sensor was cleaned?
You did not state the volume of oil added, but you should not have to add any if seviced in June. I usually wait good 10 minutes after turning the car off before checking oil.. Overfill is bad
