The ignition switch has an electrical portion that is prone to give strange symptoms like yours. You can change it out without too much cost / difficulty - use the search function < ignition switch > on the above toolbar and you will get lots of info.....
Pelican Technical Article: Boxster Ignition Switch Replacement - 986 / 987
2001 MV Agusta F4.
