					Originally Posted by insite
				 if you choose to go for 5mm spacers (47mm offset), you can use the stock bolts.  this will save you about $120.  i got my spacers and bolts from ********************************.com.  if you get new bolts, you will have to remove the cones from your old bolts and put them on the new ones (a pain). |
I disagree with this advice. If you use a 5mm spacer, you need to have wheel bolts that are also 5mm longer (part # 996 361 980 02)!
