Old 09-23-2013, 09:38 AM   #16
ppbon
ppbon's Avatar
Originally Posted by KRAM36 View Post
It's my understanding that the DOF complimented the LNE Retrofit, matter of fact I thought the LNE Retrofit came with the DOF until yesterday.
The DOF is indeed a compliment to the IMS bearing (any bearing).
You can install a DOF on your existing LNE ceramic bearing, or you can opt to purchase an IMS Kit (steel-ball or ceramic-ball) if you want to replace the OEM bearing when you install the DOF.
Again, none of the bearings on the market are the issue. They're all fine and can handle the task.
The reason why the fail is because of improper lubrication which is what the DOF addresses.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
