Old 09-23-2013, 08:00 AM   #10
Perfectlap
Perfectlap's Avatar
Originally Posted by nieuwhzn View Post
Considering the serious consequences of an IMS failure this should warrant a recall. However, a recall means that Porsche should have a solution for the problem, which they don't..
There is a solution. There are several actually. And at least one has been available to owners from the aftermarket since 2009 or maybe sooner, I forget.
IMHO the minute your car is out of warranty, since 2010, it's on you to address this issue. At this point all single row bearing cars have been out of warranty anywhere between 4 to 13 years. And to my knowledge there has never been a inventory shortage of LNE or Pelican IMS bearings. Probably because most haven't kept up with the most widely discussed issue of the Porsche engine.
However for the engines that failed before the aftermarket solutions were common place procedure, then Porsche should pony up rebuilt engines 100% simply for reputation, probably peanuts to them anyway. I think this gesture would have sent a very clear signal to owners and prospective owners that once the warranty runs out, an owner needs to stay informed by calling a independent mechanic, doing a Google search on the issue, etc. IMO if the aftermarket provides a solution for an out-of-warranty car issue then manufacturer's blame has to be reduced significantly.
BORN: March 2000 - FINLAND
