Old 09-21-2013, 03:50 PM   #1
AKnowles
AKnowles's Avatar
FWIW, I think you will do better with a set of 3/8" or 1/2" socket wrenches with allen head caps on them. It's what I use. I have a set of allen heads, tripple square, torx, etc. Not only to they work well, but they let you get the extra tourque to pop the seal safely on the drain cap. And you can use a tourque qrench to make sure you pply the correct tourque when you install it.
