Old 09-20-2013, 06:25 AM   #8
valiantechoes
Smile
Changed the right rear bearing and the noise is gone! Used the B90 tool and did not have to disassemble the suspension. Just had to drop the exhaust to get the axle dropped. BTW, two exhaust studs did break off but I just drilled out the splined stud and replaced them with nuts and bolts. A note, the B90 tool instructions said you do not have to remove the hand brake shoes and that saved a lot of extra work. Thanks for the helpful comments.
valiantechoes is offline   Reply With Quote
