Originally Posted by ppbon
Porsche started the change of the IMS bearings in the (calendar) year 1999 which is (model) year 2000. The first part of the MY2000 production run included dual row bearings, which is your particular case.
happy Boxstering,
Pedro
Hat tip to you my good sir
Originally Posted by Perfectlap
Haz, approximately how many oil changes did your double row bearing car have up until the failure began? As you shared with us your double row bearing went nearly 2 1/2 years without an oil change. Somehow I don't think the previous owner(s) were good at critical engine maintenance. Do you have the most recent coolant cap? was the coolant tank and water pump ever replaced?
I will not argue against you on those questions
I was merely pointing out that, from what I have hear from people and also read myself up on, the problems with the IMSB didnīt happen the second Porsche changed from single to double bearing.
Yes, most recent 04 cap. Expansion tank replaced, as well as the water pump and the AOS.
