Old 02-03-2006, 10:11 AM   #4
MNBoxster
Hi,
You could be suffering from a Variety of issues. I'm inclined not to blame the Battery since it's got so little Service Life (although to be fair, most Mass Produced Goods fail either early in their Life or Very Late, an indicator of how well they were made).
Possible causes could be:
A Short somewhere in the Charging Circuit which causes the battery to drain.
A Loose Drive Belt, although the Accessory Belt also drives other Ancillaries besides the Alternator, so you would probably either hear it or see it manifest itself in other faults such as running HOT as this also powers the Coolant Pump.
Battery Cables not properly tightened.
Failed Alternator.
There are a variety of easy Tests you could perform to narrow the cause. But, since it's definitely still a Warranty Item, I'd simply make it the Dealer's Problem. Charge up the Battery and bring it in. But, insist that they check out those things mentioned above and not simply slap a new Battery in the Car as this could just cause a repeat of your current dilemma...
Happy Motoring!... Jim'99
