Old 09-18-2013, 08:41 PM   #10
rp17
rp17's Avatar
Originally Posted by Verhag View Post
If your Boxster has already had the LN retro fit completed, can you still benefit from adding the DOF as described by Pedro? Or is that "belt and suspenders" approach that is not necessary? Do ceramic ball bearings as in the LN bearing benefit from this direct oil injection?
LN bearings require that it be at least inspected after 50k miles if i'm not mistaken. So I would say yes belt and suspenders. But something to consider at your next clutch change. This is good news for anyone driving 05 1/2 thru 08 Boxster /Carrera.
There are thousands of cars running ceramic. DOF sounds good to me. And there is also the solution. There are options out there.
