Old 09-14-2013, 01:24 PM   #1
thom4782
thom4782's Avatar
If you're losing a pint over several days, you have a slow leak. I don't think the oil gauge is accurate enough to prove coolant is mixing with oil. Look for intermix in the coolant tank or on the dip stick. My guess is your leak is on the front side of the coolant tank or the water pump. You might consider having a different shop look for the leak.
