Old 09-14-2013, 12:31 PM   #17
Trey T
Trey T's Avatar
That will stick out too much if you have a spacer on there.
Your limit is 996 10" (265mm or 285mm width tires) width wheel with a minimum with 23mm spacer. That's pushing it!
If you have 11" with 295mm width rear tires, you might need a spacer that's beyond 40mm spacer.
Trey T is offline   Reply With Quote
