Old 09-14-2013, 05:36 AM   #11
LAP1DOUG
LAP1DOUG's Avatar
Depending upon how aggressive you want your fitment to be, as well as what your suspension set-up is, here's a basic outline to follow:
Fronts:
8 inches wide = offsets ranging beginning with +40 to +35
8.5 inches wide = offsets ranging from +45 to +40 or so.
* tires 225 to 235 (some like to run 245 - I don't)
Rears:
9.5 inches wide = offsets ranging from +40 to +35
10 inches wide = offsets ranging from +45 to +40 or so.
* tires 265 to 285 (I prefer 275)
Again, these are based on a number of fitments that I have experiment with personally, and fitment between vehicles can vary based on suspension set-up, tire size and application of use.
Just as another data point:
A 255 with an 8.5" wheel having proper offset will fit on the front (barely). A 245 on a 9" wheel again with proper offset will also fit. I am not sure if the 255 on a 9" wheel would work though.
The front to rear stagger needs to be adjusted based on how much front camber you can run. Otherwise you will have too much understeer or oversteer. The OP's 225 / 295 combo even if it would fit, would probably result in gross understeer even with lots of front negative camber.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
