Originally Posted by dixbu
So 11's are a no go? What tire set up should work?
The tires are worn i can still figure out fitments that may work.
Depending upon how aggressive you want your fitment to be, as well as what your suspension set-up is, here's a basic outline to follow:
Fronts:
8 inches wide = offsets ranging beginning with +40 to +35
8.5 inches wide = offsets ranging from +45 to +40 or so.
* tires 225 to 235 (some like to run 245 - I don't)
Rears:
9.5 inches wide = offsets ranging from +40 to +35
10 inches wide = offsets ranging from +45 to +40 or so.
* tires 265 to 285 (I prefer 275)
Again, these are based on a number of fitments that I have experiment with personally, and fitment between vehicles can vary based on suspension set-up, tire size and application of use.
