Old 09-13-2013, 11:57 AM   #4
Foydawg
Originally Posted by pjq View Post
Soooo Foydawg, if you've had an IMS failure that stalled the car and you need to replace the IMS and bearing what about other parts of the engine? were there any other parts that failed? Was there metal in the filter or sump or fillings in an oil sample? Does the crank and bearings look good?
Got it back today after writing a $7,000 check. The parts highlights were: new IMS w/bearing, oil cooler, engine gasket set, cylinder head bolt, timing chain, elective water pump and AOS with a host of small parts.
Foydawg is offline   Reply With Quote
