aftabulis
Adam,
I think you have either a issue with the brake switch or the ignition switch.
With my 1999 Boxster, I cannot shift out of park when I depress the brake pedal.
I changed the brake switch, but the problem remained.
I can hear a faint clicking noise from the ignition switch as I attempt to press the button on the shifter. I am on my second ignition switch.
My temporary solution to the problem is this:
a) Depress the brake pedal, and at the same time push down on the shift button and turn the ignition switch.
It works everytime for me. I will continue with this technique until I work up the nerve to change out the faulty ignition switch.
My two-cents.
MNC-I
